carb'd 302 to FI 302 swap?
Just bought a 1969 F100 Shortbed with a 302 and C-4. Im thinking about switching out the engine and tranny with a fuel-injected 302 and AOD tranny from a 1990 Crown Victoria. I know I have my work cut out for me with the computer, sensors, wiring, fuel routing, etc. Does anyone have any suggestions or similar experiences that they wish to share? Are there any issues regarding compatibility with the driveshaft, shift linkage, etc. I should be worried about? Any replies are appreciated...
i've done one conversion and a transplant...converted a 83 f150/351W to 88-89 ford efi speed density and transplanted a 5.0 ho into a 81 ford fairmont. the book by charles probst covering ford eec-iv efi from 87-93 is worth every penny spent. one part of the swap people over look is the fuel system...my truck has dual tanks and you have to get fuel to the rails at approx. 40 psi for efi systems. i used stock tanks, from salvage yards, in my truck (with in tank pumps) and a high pressure pump on the frame. you also need return lines to get fuel back to the tank. i spent about $2200. it was well worth it, the truck runs great and ford efi is not that difficult if you have the right information. cheers, garsten
Hmn...
Originally Posted by n3vyk
Ford sells a booklet that tells you how to do the swap. It tells you what sensors you need to keep, where to cut and splice the harness, the whole deal. It goes for about $6.
If my 240 is locked up in my '71. I've thought about making the swap.
gnarkle
11-01-2008 01:26 PM
68shortbedmo
03-19-2007 08:34 AM
