Trailer light problems
Old Jun 13, 2005 | 05:38 PM
Ranger01boy's Avatar
Ranger01boy
Cool Trailer light problems
I have an 01 Ranger and am having problems with the driver side turn signal for the trailer light. I have checked the fuse and it is fine. does anyone have a wiring diagram for an 01 ranger for the trailer lights.
Old Jun 13, 2005 | 06:33 PM
guessrow's Avatar
guessrow
Four prong plug in:
Four prong wiring is as follows: ground, running lamps, teft turn, right turn. The ground is, of course, the plug that is different than the others. Does your left brake light work?? Most of the time when you are having issues like this , it turns out to be the trailer.
good luck, jim
Old Jun 13, 2005 | 08:25 PM
Ken00's Avatar
Ken00
Welcome to FTE!!!
I have to agree, trailer. Does it work OK without the trailer connected?
Old Jun 13, 2005 | 11:04 PM
Old Speed's Avatar
Old Speed
take a voltmeter and stick it in each hole and activate each wire. flip your lights on and test for voltage on the brown wire, do the left and right turn and do the yellow and green, and brake light both yellow and green should have voltage. test the connection on the truck. then hook it up to the trailer and test the wires on there. if you have a flat 4
Brown wire is tail lights
yellow wire left turn
green wire right turn
white is ground
if you have a 7way round or 6way round here is the diagram for them on etrailer.com
Colors on the connector: http://www.etrailer.com/faq/wiring.asp
Old Jun 13, 2005 | 11:07 PM
Old Speed's Avatar
Old Speed
double post sorry
Old Jun 20, 2005 | 08:13 PM
Ranger01boy
Talking
Fixed the problem. Bad wire from the left trailer light coming from the fuse box on my truck.
Thanks for the help
Old Jun 20, 2005 | 08:17 PM
Ken00's Avatar
Ken00
Glad to hear you found the problem.
armour01
2004 - 2008 F150
Oct 16, 2012 02:11 AM
robs01f250
Jul 29, 2012 06:01 PM
harleymsn
Nov 1, 2011 12:18 PM
flcracker9
Aug 29, 2010 01:22 PM
'01_4x4
Jun 4, 2008 09:10 PM
