Caliper slide grease
Old Jun 13, 2005 | 02:28 PM
tjay460's Avatar
tjay460
Is using anti-seize to lube caliper slides on front dual piston calipers a major no no? If so why? What do you guys use to lube the slides? The front end is a HP Dana 44.
Old Jun 13, 2005 | 02:55 PM
Torque1st's Avatar
Torque1st
Posting Legend
I use synthetic brake caliper grease. Buy it in a tube from the parts store. It works for the drum brake parts also.
Old Jun 13, 2005 | 03:03 PM
mopar's Avatar
mopar
I have used anti-seize before with out any problems, but with synthetic brake caliper grease, I think brakes are more responsive.
Old Jun 13, 2005 | 04:36 PM
quehele's Avatar
quehele
CRC Copper...
CRC makes an anti-seize compound called "Copper Anti-seize". It's good from -65 degrees to 1800 degrees. I've used it for years and it's never let me down.
Hope this helps.
Old Jun 13, 2005 | 05:05 PM
Mil1ion's Avatar
Mil1ion
Use the product that was designed for it.
You can get a little tube of Disc brake lube for $1.00 at the counter of parts stores.
Old Jun 13, 2005 | 06:13 PM
tjay460's Avatar
tjay460
Thanks for all of the input! I finally have the front axle rebuilt and now it's time check the rear. Hope things are in better shape there.
