Aerostar Ford Aerostar
4-speed, or 5?
Old Jun 12, 2005 | 02:07 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
4-speed, or 5?
I have a '91 Ext. 4.0 with the automatic tranny. This has been bothering me for some time...but do I have a 4 speed or 5 speed transmission? (Including OD)
I can shift it from 1st to 2nd, then put it in 'D' and it shifts to 3rd, and at around 47-50mph, it will shift again, and drop another 700-1000 RPM...plus, I still have OD
This is just a nussiance I have been wondering about for some time now
Old Jun 12, 2005 | 03:47 PM
93nighthawk's Avatar
93nighthawk
It is a 4 speed with overdrive, where the 97 model is a 5-speed with OD.
Old Jun 12, 2005 | 05:40 PM
bobcf's Avatar
bobcf
some times you will notice the torque converter locking.
Old Jun 12, 2005 | 11:10 PM
asavage's Avatar
asavage
FTE Community Team
The last "shift" on my '89 is the TC locking. Since I have the 4.10 rear axle, it locks at about 40 MPH at light throttle.
I didn't know that the '97 has the 5R55E. Something new every day
Old Jun 14, 2005 | 10:13 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Is there a way I can check my axle ratio? Or would this require climbing under the van and looking on the axle?
Old Jun 14, 2005 | 10:25 PM
93nighthawk
Assuming that no-one did a switcheroo on you, you can look on the drivers door jam tag and find out. There will be a spot marked Axle with a code:
Here are the codes:
Code Ratio
Conventional
22 4.10
23 3.45
24 3.73
25 3.27
26 3.55
Traction-Lok
B2 4.10
B4 3.73
B9 3.55
Old Jun 29, 2005 | 01:46 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Thank you! As soon as the Thunderstorm passes, I'll have to go out and have a look see.
Old Jun 29, 2005 | 09:54 PM
DaveMac2Vans's Avatar
DaveMac2Vans
Any way to look at the diff to see what it is?
Old Jun 30, 2005 | 12:05 PM
bertha66's Avatar
bertha66
I have a 90 EXT with 4.0 engine and auto trans, I beleave it is rated a 3 speed with OD.
Old Jun 30, 2005 | 04:55 PM
maxwgn's Avatar
maxwgn
I could have sworn I read somewhere that the 5 speed auto was offered starting in 95...any ideas?
Old Jul 1, 2005 | 10:04 PM
93nighthawk
Up to 1995 (at least the ones I have seen) A4LD
'96 4R44E
'97 3.0L 4R44E - 4.0L 5R55E
Old Jul 6, 2005 | 11:24 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Well...Looks like I have a "B9" Traction-Lok 3.55 rear end. I wish it was the 4.10 Trac-Lok though...
Old Jul 6, 2005 | 12:21 PM
93nighthawk
I wish I had a Bx rear end instead of the normal 24.
Old Jul 6, 2005 | 06:23 PM
obars's Avatar
obars
You can also locate the wire that connects to the tranny and put a switch inline to manualy control the torque convertor lock up only when you want it. handy on the hills...
Old Jul 8, 2005 | 01:48 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Yea...makes winter driving and my weekly off-roading much easier that both rear tires lock up...
