I know i am new and and i've checked the search and found nothing. I am looking to check some error codes i've pulled after putting in my Bully Dog Outlook Monitor.
U0029
P2138 - Throttle/Pedal Position Sensor/Switch D/E Voltage Correlation
U2222
Any help would be great!
Also when the Outlook is hooked up to the Map Sensor the Tranny doesn't wanna shift right and that is when i get the codes and the Check Eng light.
The truck is a 05 F250 Super Cab fx4 6.0L PSD
welcome to fte, the best ford truck web site on the net. please take some time and read the web site guide lines and area read first's on posting rules
well i can't get it to clear with the outlook hooked up, and the P2138 is the one i am worried about. The truck is not shifting correct when the outlook is hooked up, it doesn't seem to wanna run like it is ment to!
yea for some resaon bully dog wasn't open at all on saturday. I am going to try monday and see what they say. But the Power Pup downloader is great alone!!
But maybe someone else can help me out before monday
what do you mean fuel box or tuner? I hadn't pluged in the downloader if that is what you mean. I was just hooking the monitor up to make sure it worked before i did the downloader
Okay got it....Bully Dog site needs an update ......
Just on the personal side....Do not quote when responding to a post like above since you and I are the only ones posting right now. FTE Moderators are usually nice to let you know about the guide lines to new people.
Give BD a call Monday (sorry I was no help ) but it sounds like the trans is doing some learn time. If you feel it is not right your doing the best thing to wait. When your problem is solved you may in fact Help someone else in a similar situation. This is what makes FTE a nice site.
max. is correct. play it safe and wait till monday. it's not worth harming some thing if you just may possibly have received a bad tuner. bd is a good company and i know how itchie pants can get when you want to play.
good luck enjoy your ride
