EFI Fuel Problem during Ignition
Old Jun 11, 2005 | 10:03 AM
MudBugn's Avatar
MudBugn
Unhappy EFI Fuel Problem during Ignition
just wondering what i should do to my 1987 f-150 351 efi. just put everything back in order and was runnig before but now when i turn the ignition over it acts as if the truck is starving and not getting any fuel i can stomp on the gas and get the RPM up to 1300 and still be turning over the key but as soon as i let go the truck wil not idle. please any help would be helpful
Old Jun 12, 2005 | 08:09 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jun 12, 2005 | 09:04 PM
Popa Tim's Avatar
Popa Tim
Do you hear the fuel pump prime when you turn the key to run?
Please check your fuel pressures. Turn key off & on 3 times and leave on, FP should be around 39psi and hold it within 5psi for 30 seconds after the fuel pumps shut off.
Best wishes,
Popa Tim
