Sponsored by: Auxito
A/C Problem
Old Jun 10, 2005 | 09:40 AM
canoeman's Avatar
canoeman
A/C Problem
Hello, /><O></O>
I'm new here so go easy. The problem I am having is that I pulled my battery to reset my air flow sensor and idle. After that I have to A/C. I checked the manual and it said to do this and that which I did and still no A/C. I believe that the compressor is not turning on because I don't get that drop in idle when it used to turn on. There is coolant in the line. I found the fuses and they look fine, but I did not test the fuse, diode or relay. Anybody who might have info on this it would be appreciated.<O></O>
Thanks<O></O>
Old Jun 10, 2005 | 06:48 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
