Help
Old Jun 10, 2005 | 09:39 AM
docsam's Avatar
docsam
Question Help
Have a 2001 powerstroke with auto transmission that blows fuse 19 under dash when shifted to reverse. Has anyone seen this???
Old Jun 10, 2005 | 09:47 AM
Steve_250's Avatar
Steve_250
I'm not sure what #19 is on the '01.
Do your backup lights come on after the fuse is blown?
I'm wondering if it's the Digital Transmission Range (DTR) sensor located on the drivers side of the tranny.
Do a quick check and make sure all your wires are hooked up at the tranny and clean.
Your stealer has 'em at fifty bucks a pop if it's bad.
Old Jun 10, 2005 | 09:48 AM
bilder12's Avatar
bilder12
hi doc, welcome aboard to the best place for information.
Have you had any recent work done to the rear of the truck ... like a new hitch or someone install some wiring? I am not sure if the backup lites get their power from the trans switch or the steering column switch. Just some places to look.
Old Jun 10, 2005 | 10:21 AM
docsam's Avatar
docsam
help
Hi steve, Thanks for replying, no i have had no wiring work or trailor hitch type work done. This was my first thought and have checked trailor wiring as best as can. Can not find any nicks or shorts that are visible.
Old Jun 10, 2005 | 10:27 AM
Steve_250's Avatar
Steve_250
Check the two plugs on the tranny right above the cross member and the three on the frame rail. Pop 'em and clean 'em up. Do you have backup lights after the fuse blows?
Old Jun 15, 2005 | 12:00 PM
docsam's Avatar
docsam
Sorry for the delay in response. Yes i have back up lights after the fuse blows. I pulled all the connectors you suggested and the trailor connectors and cleaned them with a contact cleaner. I have had no more failures since then!! I do not want to claim success this early but i think something changed. I can't thank you enough for your help.
DOC
Old Jun 15, 2005 | 05:36 PM
Steve_250's Avatar
Steve_250
DOC
Great! So far so good.....
Those connections can get grungy under there.
