Fuel system problem
Old Jun 10, 2005 | 08:30 AM
fta9633's Avatar
fta9633
Fuel system problem
On a 96 150 4X4 w/351 Auto trans, I am experiencing what feels like a ignition failure or fuel cut out. This happens only for the first few minutes after a cold start and only just off idle under very light acceleration. When the engine starts to struggle, even a little more pressure on the accelerator will stop it and the truck runs fine. Idle is smooth. I have changed air/fuel filters and plugs/wires. Anybody have any ideas???
Old Jun 10, 2005 | 08:42 AM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to 351W forum.
Old Jun 10, 2005 | 03:00 PM
Kemicalburns's Avatar
Kemicalburns
Pull codes, this is always the first step before you start throwing parts at an unknown issue. www.fordfuelinjection.com
Old Jun 19, 2005 | 07:44 PM
fta9633's Avatar
fta9633
Still Trying
I used the code reader at the local AutoZone store and it showed no faults. The problem does not appear to be temperature related after all, but still is cutting out at very light throttle. Give her a little more and things run great. This is a lot better than the Chevy it replaced! (read everything plastic broke and fluid leaks d'Jour!)
Old Jun 20, 2005 | 08:37 AM
Kemicalburns
whats your timing set at? should be 10*btdc with spout removed. you might also run some seafoam thru it. both the intake and gas tank.
