Stuck ignition switch
Old Jun 9, 2005 | 08:43 PM
haamezzed's Avatar
haamezzed
I drove my 1989 F250 to the post office, and shut it off. When I came back the ignition switch would not budge. Had to tow it home. Has this ever happed to anyone else? I don't know if I need a locksmith or a "not so new" replacement column. I'm in the Church parking lot and would like to make room for Sunday. Please advise, Haamezzed
Old Jun 9, 2005 | 09:40 PM
quicklook2's Avatar
quicklook2
sometimes the steering wheel catches the mechanism inside. try moving the steering while you turn key. you do need to use some force.
Old Jun 10, 2005 | 07:01 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome haamezzed, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jun 10, 2005 | 10:23 PM
ironworkinman's Avatar
ironworkinman
hi Haameezed...MY 91 column would jam the ignition switch,rocking the wheel left and right loosened it up...then i found that the tilt wheel always jamed the switch when in the up position....shifting the tilt down would free it up..this is after i did a minor rebuild to regrease the inner pawl bar..good luck
Old Jun 12, 2005 | 05:49 PM
mike93's Avatar
mike93
when you do get the ignition to move per above suggestions use some Lock Ease from
Permatex inside the ignition lock. It's a liquid graphite and is a little messy. I've also made it a practice of only turning the key with the tilt wheel down in the level position.
Mike.
BuckHunter1960
May 22, 2016 03:47 PM
logcabinford
Apr 16, 2012 09:14 PM
teppler
Sep 16, 2011 09:53 PM
orangedbowl
May 10, 2005 11:09 PM
