ball joint grease fitting question
Old Jun 9, 2005 | 06:53 PM
eyball's Avatar
eyball
Well I replaced my other lower ball joint with the moog part on my b4000 and when I was installing the grease fitting it snapped of. I tried to remove it with one of those craftsman removal bits and it snapped off in the broken fitting. I know, what luck huh? Any ideas on what I should do? I was able to get a good amount of grease into the joint before the craftsman but broke off in it. Should I use one of those needle grease adapters when I need to put in more grease? I don't want to replace the ball joint again unless I am going to replace the uppers. THanks!
Chris
Old Jun 9, 2005 | 11:15 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
The easy out is probably harder steel than a drill bit and even if you succeed in somehow drilling it out, there will be metal shavings in there. With the thing incapable of holding grease and stopping water from getting in there, you're kinda stuck unless you can somehow seal the opening. You might have luck with a needle nose pliers ground down, but I can't see how much room you have to work. Myself, I'd devise a way to seal it and run it, as much as I hate to say it. If it really bugs ya, replace it.
BTW, any chance some of this easy out is sticking out? If so, think welding.
Old Jun 9, 2005 | 11:21 PM
Help I M Stuck's Avatar
Help I M Stuck
better to be safe then sorry..so take the time and replace it.
FordTruckChuck
1997 - 2003 F150
Oct 27, 2015 04:01 PM
spinella
Apr 29, 2013 10:52 AM
hndacr
Feb 1, 2011 07:55 AM
cbradford
Oct 20, 2008 07:46 PM
vze2sgxa
Sep 17, 2008 05:28 AM
