Resistor Wire
Old Jun 9, 2005 | 06:12 PM
cushing's Avatar
cushing
Resistor Wire
My 78 F150 fried the resistor wire, at one time today it got hot enough to start melting wires but I caught it in time, now when I let go of the key the engine dies. This truck has had a problem with the ign just shutting down than refiring amazing I still have a muffler. I have replaced the module, stator and ignition switch. Today I replaced the coil and all was going good until I tuned it off after a 20 mile drive and when I went to start it will not run on less than 12V. Thanks for the help.
Jim in WI
Old Jun 9, 2005 | 08:12 PM
Mil1ion's Avatar
Mil1ion
So why didn't you replace the resistor wire ?
They melt like a fuse >
When they melt it is telling you that something shorted out ,that has to be repaired first though.
There is the fusible link in the harness & the resistor wire (PINK) coming out of the ignition switch.
