rear leaf springs
Old Jun 8, 2005 | 09:53 PM
Ford150/428/dud's Avatar
Ford150/428/dud
rear leaf springs
I got looking at my friends 78 F150 4wd and the back leaf springs are cracked and the shackels are about to fall off. The current springs on it are 3 inches in width. Im woundering if i could put a pair of 2 and a half inch springs on. I have a 2wd frame with the springs and shackles on it in good shape. Everything should line up if i use the springs and shackels off the 2wd.
Old Jun 9, 2005 | 07:55 AM
Torque1st's Avatar
Torque1st
Posting Legend
Should fit up with a lowered weight capacity. Have fun.
Old Jun 9, 2005 | 08:39 PM
Ford150/428/dud
I measured every thing and it should fit up right. I just drilled the shackle rivits off, what a mess there was about a 8th inch thick flake of rust behind the shackles. Also the 2 and a half inch springs front shackle doesnt hang down as far so it would relieve a little drive shaft angle.
vochy
Sep 24, 2021 05:58 PM
NWO_diesel_nut
Jan 22, 2008 02:40 PM
ramtoo
May 26, 2005 08:21 AM
