Air Conditioning Issue
Old Jun 9, 2005 | 05:35 PM
chickenboy129's Avatar
chickenboy129
I've got a 2001 F150 4.2 manual with about 79K on it. I'm having an issue with the AC. For the most part, the AC doesn't run at idle. The clutch just kicks on and back off. When I'm reving the motor above 2K (moving or not) the AC works fine.
Any ideas on what could be causing this issue?
Old Jun 9, 2005 | 08:18 PM
chickenboy129
I found that it's the high pressure switch. I can hear the switch cycling. I can understand if there is a high pressure issue, but why would it be only at low RPMs.
Old Jun 9, 2005 | 08:32 PM
BrianA's Avatar
BrianA
Not sure, unless the slower turning compressor is not able to keep enough pressure to satisfy the low-pressure switch.
I had the same thing happen on a previously owned Expedition.
Old Jun 10, 2005 | 05:37 PM
NHRstein's Avatar
NHRstein
Hey something I do know about, yay!!
Anyway when you rev your engine your cooling fans rev with it, creating more air flow through the condensor. Try cleaning your condensor, a dirty condensor is usually the culprit on almost every high pressure issue in the HVAC world.
//John
Old Jun 11, 2005 | 11:55 AM
chickenboy129
NHRStein...you have the accepted answer. I checked the condensor and it was clean, but it got me thinking. I run electric fans. I hadn't noticed before, but they weren't cutting on when the AC Compressor did. I found I had a bad connection on the lead from the fan relay to the AC Compressor. So it was the lack of airflow over the condensor that was causing the issue after all.
Thanks for everyone's help.
Old Jun 11, 2005 | 04:37 PM
NHRstein's Avatar
NHRstein
glad to hear it worked
well that's good news, glad I could help.
//John
Scottmcp5
Sep 2, 2014 01:12 PM
Robby Nash
Dec 18, 2012 01:33 PM
redman84
21
Oct 27, 2012 02:15 PM
BuiltFordTough!
Ford Truck Parts for Sale
Aug 1, 2012 11:42 AM
CrewCabLongbox
Jul 18, 2012 10:29 AM
