fan switch...
Old Nov 21, 1999 | 04:25 PM
familyman's Avatar
familyman
fan switch...
my fan switch -- to the defroster, heater, etc. -- on the dashboard only works on HIGH. Before I go taking my dash all apart, are there any pointers out there that might make my task easier? ie fuse? disconnected wires? This is a 93 F-150. Thanks.
Old Nov 22, 1999 | 08:29 PM
kioolt's Avatar
kioolt
fan switch...
There is a resistor mounted in the air stream somewhere that is for the lower speeds only. Also the high speed uses a separate fuse. I would check the resistor and the fuses first. I'm not at home now or I would check to see where the resistor was located exactly. I might be able to help you more when I return.
Old Dec 7, 1999 | 07:40 PM
kioolt's Avatar
kioolt
fan switch...
The resistor that I mentioned in my earlier post is located under the hood on the right hand side of the truck near the firewall. It has four wires on it. Orange/black, Light green/white, yellow/red, and black. I believe these colors are correct. The fuse I mentioned before does not exist. Let me know if you need additional help.
Old Dec 7, 1999 | 08:30 PM
Bill's Avatar
Bill
fan switch...
Eallend7
38
Apr 21, 2013 06:24 PM
scotttahoe
Feb 4, 2013 08:33 AM
Mrbiff
Oct 27, 2011 10:30 AM
snoschu
Sep 2, 2009 07:55 PM
