water pump issue? 223
Old Jun 8, 2005 | 08:41 PM
64f100guy's Avatar
64f100guy
i do believe that i have a bad water pump. the first day i went to work on it, i checked all fluid levels, as well as coolant level. the coolant was full, which suprised me. after cranking on it for a while and trying this and that, i heard coolant dripping. i found out the source was the water pump. the coolant was leaking out of 2 holes in it, one in the top, and one in the bottom. it was not leaking around the seal. 2 days later i went back to put these parts (tune up) on(yesterday) and realized the coolant had completely leaked out, without anything being done to it. is there a purpose for these 2 holes in the water pump? is there supposed to be something attached there? i.e. screw or bracket? i was told by a friend to watch it carefully, and it may clear up after it runs, but once i told him that it all leaked out he didnt look as certain it would clear. what should i do? i dont want to buy another pump if it has the same 2 holes that leak.
i have a 64 223 six. performed tune up if that matters.
Old Jun 8, 2005 | 08:53 PM
barry's Avatar
barry
No, those 2 holes are for the coolant to come out, once the seal inside is blown. They call them "weep holes" . Don't wait, replace the pump. The seal dried up from sitting. It's now toast as they say.
Barry
Old Jun 8, 2005 | 08:58 PM
64f100guy's Avatar
64f100guy
what about a seal?
well, do i need a seal as well? to go b-tween the pump and block?
where do you suggest i get it from? i have found one from Sacramento Vintage Ford i believe.
Old Jun 9, 2005 | 12:35 AM
nealjpage's Avatar
nealjpage
I'd just go to a reputible parts house. It should come with gaskets, too. A little Indian Head or some similar hardening gasket sealer, and you're good to go.
Old Jun 9, 2005 | 12:55 PM
Head Hermit's Avatar
Head Hermit
I replaced the waterpump on my 64. The gasket comes with the pump. I picked mine up at the local ford dealer.
Old Jun 9, 2005 | 01:27 PM
nealjpage's Avatar
nealjpage
My father's advice was always "Hell, I've driven hundreds of miles on a leaky waterpump. You'll be OK." Important note: my dad was never real good at preventitive maintence, so I'd disreguard his thoughts all together. If it's weeping, it won't be long until the bearing goes out, which can do any number of things for you: fry your belt, overheat your engine, or even send your fan through your radiator.
Now, I'm not up on Ford engines, so I'm not sure if the 223 uses the same pump as either the 240 or the 300, but reman units are less than $20 for either of those engines.
Old Jun 9, 2005 | 04:29 PM
64f100guy's Avatar
64f100guy
Question water pump question
does anyone know if the water pump on the 64 223 has a pressed on pulley, or a bolt on? even if it had a bolt on pulley, couldnt i order one with a pressed on pulley to replace it? shouldnt it be the same size and stuff?
Old Jun 9, 2005 | 05:06 PM
minishtr's Avatar
minishtr
Mine is bolt on.
Brian
Old Jun 9, 2005 | 08:12 PM
barry's Avatar
barry
Go to a good parts house like NAPA and ask for a waterpump for your year truck. Give the engine size. It's all rebuilt, ready to mount. You can't replace the seal like you would an axle seal. It's inside the pump body. Just get a pump. It comes with a gasket. Get new coolant while you're there and replace it. If you use the old pump and start driving it, you are going to get stranded somewhere. Replace it. Finished business and you're good to go!
Barry
BillC1009
16
Aug 7, 2022 10:16 PM
goatsauce
Escape & Escape Hybrid
Oct 24, 2016 10:06 AM
koplinhagen
Oct 5, 2015 07:10 PM
88grandmarquis
Nov 3, 2009 07:09 PM
Scott's 88 F150
Mar 8, 2004 07:19 PM
