Instrument Cluster Fuse
Old Jun 8, 2005 | 11:34 AM
greydz's Avatar
greydz
I have a 2002 F250 that keeps blowing the instrument clusterfuse when I engage or disengage the overdrive switch. It only seems to happen when the truck is motion. Any ideas on what's causing the problem?
Old Jun 8, 2005 | 05:50 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jun 9, 2005 | 12:21 PM
Franklin2's Avatar
Franklin2
See if it's related to turning the steering wheel. If it is, you will probably have to take the steering column apart and look for a wire rubbing somewhere.
