Sponsored by: Real Truck
Heater/Defrost Vent Question
Old Jun 7, 2005 | 07:13 PM
Studenut65's Avatar
Studenut65
Hey guys,
I noticed that when I turn my heater/ac unit to the dash and floor vents, that it sometimes switches to the floor and defrost vents even though it is still on the dash/floor vent setting. It might also be helpful to note that my ESOF works but that I have to lock the hubs b/c the seals in my axle are bad. Is there a connection between my hubs and my vents since its all vacuum controlled? Also, have any of you experinced this problem and know an easy fix? Thanks for your time and suggestions!
Nate
Old Jun 7, 2005 | 08:40 PM
high ho silver's Avatar
high ho silver
Start with the vacuum canister under the hood. Trace the line from there to the firewall. Look for any signs of chafing especially where it goes behind the a/c acumulator. If all looks good there, go under the dash from where the line comes into the cab and trace it and all the others back to the switches. Some of the lines are a real pain to get to. You may have to remove a few things.
Buck268
2009 - 2014 F150
Dec 17, 2016 01:19 PM
sunny.richter
Oct 4, 2015 08:32 PM
CAKingRanch
Sep 17, 2015 04:22 PM
AeroStarOwner
Aerostar
May 9, 2012 11:01 AM
cr9c1
Jan 1, 2007 01:57 PM
