Engine cuts-off
Old Dec 10, 1999 | 06:27 PM
Ben G.
Guest
Posts: n/a
Engine cuts-off
Hey Forders,
I have a 1989 F-150 4x4, 4.9L EFI 6-cyl. 128,000. After running my new rear tank nearly empty, (mileage test), I have had a problem which may or may not be a coincidence. My engine will suddenly shut off while driving no matter how much gas I have in the tank. I have had success in stopping, switching tanks, waiting for the pump to bring up gas and restarting. I can then switch back to the rear tank, no prob. Last night however, the tank switch was no help. Had my brown beauty towed to the Ford dealer near work, but when it got there, it started and they could find no reason for the stalling. No charge, but no solution. I plan on changing my fuel filter and adding cleaner to the tank this weekend. Do you think this will solve the problem, or is this a problem anybody has heard of before? (I'm use to alot of other F-150 quirks)
Thanks for your help!
Ben G
Maine
Old Dec 15, 1999 | 12:32 AM
david_1's Avatar
david_1
Engine cuts-off
I have an 87, 300/6. Mine did the same thing driving on I-65. Waited a few, restarted and ran fine. Next day died in McDonald's drive thru. Had to be towed. Dealer changed fuel filter and truck hasn't died since. (At least not for that). I now change fuel filter twice a year.
Old Dec 15, 1999 | 06:34 PM
Ben G.
Guest
Posts: n/a
Engine cuts-off
I changed my fuel filter, added FI cleaner, but the thing cut-off agin today. Helppppppppppppp!
Ben
Old Dec 15, 1999 | 09:44 PM
Jay's Avatar
Jay
Engine cuts-off
Been
First check to make sure youre getting fuel to the engine.You should be able to spray some fuel injection cleaner into the intake if it starts and dies you will know its a fuel problem if it won't start at all its probably electical.I had the same problem after changing fuel pump and filter I figured out it was the switchover valve for the fuel tanks.
Good luck.
P.S. Please let us know what the problem ends up beeing.
Old Dec 15, 1999 | 10:01 PM
Zman's Avatar
Zman
Engine cuts-off
dfletcher
May 23, 2014 02:09 PM
94GreenTruck
May 23, 2014 09:27 AM
trip1040
15
Feb 5, 2014 01:02 PM
gcfisher75
Dec 11, 2002 04:33 AM
