TPS Problem
Old Dec 16, 1999 | 07:19 PM
BlueBronco's Avatar
BlueBronco
TPS Problem
I have a 1990 bronco w/ a 5.8 liter engine. I tested the tps sensor, and I was unable to get the 1v from the sensor. However, I was able to get the 5v reference voltage. I just discovered it because the computer gave no codes. I am concerned because of the lack of code. Can the tps fail and not set a code in memory? Or is there possibly another problem. Please Help!
Old Dec 17, 1999 | 08:22 AM
Phillip Guidry's Avatar
Phillip Guidry
TPS Problem
First I'd like to ask if you are using a digital multimeter? An analog meter,under 1 volts won't really make the needle move unless you have a large scale like on a Simpson meter.Also, did you rotate the throttle and get some increase in the voltage on the wire that was supposed to have 1 volt or less ? I wouldn't worry about it not settin' a code,even if it turns out to be faulty, a lot of people have changed them without ever seeing a code.
Phillip
Old Dec 17, 1999 | 10:35 AM
deleontow's Avatar
deleontow
TPS Problem
