low oil pressure?
Old Jun 7, 2005 | 12:32 AM
Quackhead94ranger's Avatar
Quackhead94ranger
low oil pressure?
i have a 78 f150 with a 400 in it. i recently put the engine in and for a month it ran fine. all of the sudden my oil pressure gauge is acting weird. itll be fine for 10-15 minutes and then it will drop completely down to nothing, occasionally it will move back to high but then will go back to low. (wether im on the highway or around town its the same) the engine is running really good and doesnt seem to have any problems and the oil level is fine. i know it could be a bad oil pressure sending unit and im going to change it out tomorrow. any ideas on what to do.
Old Jun 7, 2005 | 01:05 AM
titanicf150's Avatar
titanicf150
Quackhead,
I would verify the erratic reading with a known second gauge. Put a tee in and see if both gauges dip low at the same time. If the pressure actually is dropping then you may have something washing around in the oil pan. I ran into a John Deere tractor three years ago that had exactly the same symptoms and it had a chunk of tee shirt that the farmer was using to check the oil with wrapped around the sump pickup. ( dont know how he dropped it in there) I know that was a tractor but oil pumps are oil pumps. Or possibly the oil pump pickup tube is coming loose. Has it got the 4X4 pan? Because that pickup tube is alot longer than the 4X2 one. If it was loose it would tend to suck air rather than oil, especially when it warmed up. I guess first see if it's just the gauge screwing up.
Ken
Old Jun 7, 2005 | 01:40 AM
Quackhead94ranger
im going to assume its got the 4x2 pan because the engine is from a 74 ltd. ill try what you said with the other gauge and let you know what happens.
Old Jun 7, 2005 | 05:56 AM
Heavy460's Avatar
Heavy460
Wow,tee shirt thats crazy.I was draining the fuel out of the tank of my friends Firebird,and sucked out at least a roll of toilet paper or paper towel.It took three differnt pumps to just get the fuel out.The first two got cloged.In the old days they used ping pongs if some one did not like you.
Old Jun 8, 2005 | 12:40 AM
titanicf150
Quackhead,
There you go. If you did not change the car pan off of it than it's the 4X2 pan. The 4X4 pan has a rear sump and a shape that gets it out of the way of the front differential. It holds two more quarts of oil too. My daughter bought a 78 F250 4X4 that had a car engine and pan in it and over time the diff created its own dent to fit into. She finally changed it to the rear sump pan.
Let me know how it works out. I hope it's just the gauge screwing up, thats easier to fix.
Ken
Old Jun 8, 2005 | 12:42 AM
titanicf150
Heavy 460
Ooooh. toilet paper in the tank, some people are so mean. Thats low.
Ken
alchemist1
Mar 11, 2013 07:36 AM
jafy31601
Jun 16, 2011 08:56 AM
Munch
Apr 21, 2006 11:59 AM
mstepchinski
Sep 17, 2004 04:02 AM
byerks
Jun 1, 2001 02:39 AM
