venport - Haven't been to maob yet. I just didn't trust my bronco that much yet. Still had the stock motor and cooling system. You might have seen that my bronco was hit by a Drunk driver so if I get a better bronco, I will probably be planning a trip to Moab!! You wheel?
J.D.
i used to do a lot of rock crawling when i was stationed in SD nothing to extreem but it was a blast.
I would like to take the psd down to moab been many many years since i have been there. I wont do any thing to complicated Cant afford to take the chance of braking my daily driver.
Now i do more mudding and trails than anything there is not much else to do in northern utah wish i knew it up here a little better.
The best local mud pit is by a maveric rite next to the base.
by the way
Thanks Max, I am looking for a new one as well (see post above yours). I have (had) a lot better articulation than that, but the weight of the motor just popped the rear end up a ways.
See this link for a comparison just after I added Spring Rockers from BC Broncos Flex
Sorry to hear about the drunk-bump. That bites. But, the articulation looks great! I'm gonna have to check those Spring Rockers. Thanks for the info!
Max - Some folks have said that those rockers are dangerous, but others have sworn by them??? I only got to try them out on one trip before my bronco got smashed, so I can't really say I have a lot of experience with them.
