Minor Oil Leak
on
mine also leaked here so and the nut on the out side was loose so last week i tightened it so i will see if it helps. the probelm with this leak is that the housing the dipstick goes into enters the oil pan from the inside then is held tight by the nut on the outside. so if tightening doesn't help i beleive the o-ring or gasket that seals it is on the inside and pan doesn't some out with out pulling the engine out. so try to tighten that large nut with channel locks.
hope that helps
tim
hope that helps
tim
