air bypass/300-I6
Old Dec 20, 1999 | 09:13 AM
timbo's Avatar
timbo
air bypass/300-I6
Posted earlier about the air bypass on my 90 F150 300-I6. Truck had been returning a 22 or 23 error code under engine self test and not getting really good mileage. Tracked this to a dead solenoid on the air bypass valve, parts houses call it the idle air controller. Replaced it Sat. and what a difference, smoother running, lower idle and I can tell already better mileage. This truck was running poorly when I bought it back in Aug. Since, I have spent about $250 on general maintenance, tune up and new ACT,ECT, O2,MAF/MAP sensors and air bypass valve. If your 300-I6 is sick, learn how to do the engine self test, track the codes to their source (may be one of these sensors), and replace if necessary. It will put new life in your stump puller engine!
Old Dec 21, 1999 | 08:27 PM
Jim_1's Avatar
Jim_1
air bypass/300-I6
Where did You learn to do this Self test? I just bought a 1990 F-150, 4-speed, 300-6 engine. I love it so far and would like to improve gas mileage.
Old Dec 22, 1999 | 08:35 AM
timbo's Avatar
timbo
air bypass/300-I6
Jim,
You can get info on how to run the engine self test at: <a href="http://dalidesign.com/hbook/eectest.html">http://dalidesign.com/hbook/eectest.html</a>
Isn't hard to do and only requires a fairly common jumper wire to do it. You basically get your computer to output engine error codes through the check engine idiot light on the dash. A Haynes or Chilton's manual (about $20 each) also is a good investment. If you're getting 15 to 20 mpg in town and down the road your I-6 is tuned well and running right.
Old Dec 22, 1999 | 08:46 AM
timbo's Avatar
timbo
air bypass/300-I6
Jim,
Forgot to mention...read Phillip Guidry's posts about cleaning the air intake throttle body tubes and air bypass valve. This is real easy to do on a 300 I-6 and improves performance greatly. If you can't find that post, go to the top of the page and click the search button, follow directions, and search for phillip guidry or just guidry. If you need help on this, post back or email me and I'll describe how to do it on a 6.
Old Dec 22, 1999 | 08:56 AM
Phillip Guidry's Avatar
Phillip Guidry
air bypass/300-I6
Alm200
Mar 1, 2014 08:07 PM
Dannym
May 26, 2006 01:09 PM
crystaldragon
Jun 27, 2003 02:43 PM
danm
Feb 14, 2000 09:08 PM
