Ignition Trouble
Old Jun 6, 2005 | 12:34 PM
Cylinder Head's Avatar
Cylinder Head
Ignition Trouble
I have an 85 F-250 with a 300 six with intermitten spark problem. I found that if I unhook the spout wire from the icm the truck will start and run fine. The book says that the pcm (computor) is shorting out the system. I need to know if I can putt any pcm in from an 80's 300 six truck with a carb or do I need a certain one?
Old Jun 6, 2005 | 01:00 PM
wtroger's Avatar
wtroger
I would dump the codes from the computer and see if it tells you anything. I would also look for a bad ground circuit. If you do replace the computer then I would recommend finding the right one. And it all else failes I would change it over to Duraspark II.
