General Automotive Discussion
Starting an automatic with a dead battery
Old Jun 5, 2005 | 07:13 PM
southpaw's Avatar
southpaw
Question Starting an automatic with a dead battery
A few years ago I was taking a vehicle in for its license inspection. A young fella in a pretty yellow truck was in front of me... Don't remember the make and model but he was fixing it up.
As he was leaving the motor killed and his battery was shot. I told him I'd give him a jump when they were done with me.
He said if I'd push him that'd be just fine. I said - but you've got an automatic? He said yup but it was tight enough that he could compression start it.
So, if I remember right, we both pushed it backwards a few feet. Then he jumped in the cab and I pushed him forward - like six inches and vroom he took off waving.
Now I might have some of this a little turned around since it was a few years ago. But I've since wondered how that truck started.
Can someone explain it to me?
Mike
Old Jun 5, 2005 | 08:09 PM
furball69's Avatar
furball69
I wouldn't think it possible with a torque convertor between the crankshaft and transmission. If you put your auto vehicle in gear, on a hill and let off the brake does the engine turn as the car rolls down the hill?
Old Jun 5, 2005 | 08:11 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
hmmm...
This has me bemused, I have never tried it, purely because I never thought it would work.
I spose though in theory if you got enough road speed up, and then put it in the 1st selector it should work, shouldn't it?
Old Jun 5, 2005 | 08:14 PM
Franklin2's Avatar
Franklin2
The only automatic tranny I know of that could be roll started was the old 2 spd powerglides in the late 50's early 60's chevies. This is because it had two oil pumps. One was up front driven from the torque convertor like every automatic has, and it had another on the tailshaft, which could be turned if the car was towed. It would build enough pressure up in the system to activate the tranny circuits if you pulled it up around 20mph.
Do not have a clue what happened in your situation. If you do not have any pump pressure, how can you lock the planetaries so power is transferred through? Even if power was transferred through, you would still have to get some rpms up, to compensate for torque convertor slippage.
Old Jun 5, 2005 | 08:24 PM
Casey's Avatar
Casey
Yes it will, if the engine is running.
The torque converter isn't the problem. As long as it is full of oil it will transfer torque in either direction.
The problem is that without the engine running (on most automatics) there is no pressure to engage the clutches and/or bands that are needed to spin the engine. Some transmissions, and they are rare, have a pump on the output shaft that will create pressure to engage the clutches/bands without the engine running. If the trans has an output pump you can push start it.
Old Jun 5, 2005 | 08:48 PM
FSC's Avatar
FSC
If the car was made in the fifties or earlier, it may have a rear pump in the transmission and may be capable of push starting, none of the automatics since then have a rear pump and cannot be push started.
That said, there may be one that I'm not aware of.
Old Jun 5, 2005 | 08:56 PM
kabcpapc's Avatar
kabcpapc
Franklin2 is correct about the older powerglides. My dad, one of his friends and myself went fishing at Lake Seminole, Ga back when I was in high school. He had a 1956 Oldsmobile which he used to pull our 17' boat. We had just launched the boat at dusk to drive it to our lake side campsite and he tried to start the car to pull the boat trailer out. Starter went south. He got one of the park rangers to pull him out of the water with a tractor. The ranger pulled him around the park until they got up enough speed and the Olds engine roared to life. We drove it into town and was very lucky to find a mechanic willing to work after hours to install a rebuilt starter. Our fishing trip was not delayed.
Old Jun 5, 2005 | 10:10 PM
V10KLZZ71S's Avatar
V10KLZZ71S
I have started a Ford vehicle by pushing it about 45 mph, I cant remeber, I believe it was my 63 galaxie.But I remember growing up it was widely known you could start automatics by going 45 or faster.
Old Jun 6, 2005 | 12:57 AM
fellro86's Avatar
fellro86
up until 67 the 'glides had the rear pumps, and I think that somewhere in the 50's and early 60's Ford and Chrysler also had som rear pump models as well...
Old Jun 6, 2005 | 07:16 AM
Casey's Avatar
Casey
GM used a rear pump in a front wheel drive Cadillac in the last 10 years. I don't remember which model it was.
Old Jun 6, 2005 | 10:28 AM
southpaw's Avatar
southpaw
I wish I would've paid more attention but I had no idea the truck would actually start.
If I were going to make my best guess: The truck body was GM - looked early 70's - but he'd just painted it and had no trim or moldings on it to speak of. I have no idea what he had for a drive train - It was definitely a project for the kid. He'd just got it to the point where he could drive it and needed to get it licensed. The interior was still tore apart.
Here's another part I might have confused... I can't remember whether we pushed it forward first and then it started when I pushed it backwards or vice versa.
I also don't know whether it was in drive, low, reverse or what.
I do know I wasn't pushing him at 45+. So far still a mystery.
Old Jun 6, 2005 | 03:05 PM
bigdaddyII's Avatar
bigdaddyII
My cousin pushed started an 85 f150 auto. He was being towed with no battery in the truck and he slammed the shift from neutral to first and the dang thing started. I was sitting right next to him and didnt think it was possible. I have since tried reproducing it and could never do it.
Old Jun 6, 2005 | 06:36 PM
ItsReallyDarren's Avatar
ItsReallyDarren
My friend had an AMC pacer that loved to eat up batteries. It would sit in the garage most of the time until we felt the need to relive the adventures of Bill and Ted . To get it started we would put the car in drive and just push it down his driveway. Granted he had long driveway that was slanted downward. By the time we reached the end of his driveway we would have mangated to get the thing started and we would just drive off.
Old Jun 6, 2005 | 11:15 PM
e1p1's Avatar
e1p1
We did a roll start with an old 1960's Volvo automatic. Pushed it to the top of a hill and got it up to 40+ with the key on, slipped it into drive and zoomed away...
Old Jun 7, 2005 | 01:59 AM
DailyDriver's Avatar
DailyDriver
Interesting thread.
If I remember correctly, I had read sometime back in an automotive Q&A column this very question. The answer was the same as some here, that one had to get the vehicle going about 40mph in order for it to work.
Here's another angle. If one has two gas tanks and one of them runs out of gas on the highway, the engine is dead. Switch tanks and the engine comes back to life. So, if the engine is dead then it's not driving the transmission but the transmission is driving the engine. Would this follow the same theory as coast starting an automatic? I've switched tanks on my truck going as slow as 30mph and had enough speed for the engine to fire back up after the fuel as reached the carb. Thoughts?
