Sponsored by: Real Truck
Kyb Shocks
Old Jun 5, 2005 | 05:47 AM
SPEC's Avatar
SPEC
Kyb Shocks
Does the piston go up or down when you install? I put the boot up and
this makes the piston on the up side.
Thanks
John
Old Jun 5, 2005 | 07:05 AM
Marcus6679's Avatar
Marcus6679
Usually you want to install shock absorbers so the piston and boot are on the bottom, that way water, mud, etc. doesn't have a place to build up and damage the shock or hinder its operation.
Old Jun 5, 2005 | 10:02 AM
SPEC's Avatar
SPEC
Went out to flip shocks over, discovered they mount only
one way. Boot and piston up.
Old Jun 5, 2005 | 10:23 AM
Rongold's Avatar
Rongold
Talking Shock Installation
Shocks are ALWAYS installed with the chrome plated rod UP, and the body of the shock below it. All the valving is in the bottom, and to work properly, it must remain vertically oriented with the chrome rod up. The piston is actually in the bottom of the shock--The chrome plated rod that you see is attached to it. The piston rides up & down in the bottom housing, in oil, and has valves in its' head that determine how stiff or soft it is. Steering stabilizers are a different form of shock absorber--They are designed to be mounted horizontally.
RON
Old Jun 5, 2005 | 10:28 AM
kabcpapc's Avatar
kabcpapc
RON
The Bilsteins that came with my Superlift kit mount with the chrome plated rod down and the body of the shock up, both front and rear. I guess it depends on the manufacturer.
Old Jun 6, 2005 | 11:23 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
They have a seperate reservoir, the Billstiens, don't they?
That's why they can mount whichever way ...
Old Jun 6, 2005 | 11:42 AM
kabcpapc's Avatar
kabcpapc
Krewat
My Bilsteins do not have the reservoir unit. They were the 5100 series.
Old Jun 6, 2005 | 12:36 PM
krewat's Avatar
krewat
I'll shut up then
Old Jun 6, 2005 | 02:32 PM
2000silverbullet's Avatar
2000silverbullet
Yeah, my brother in law and I both have 5100 series Bilstein's (on lifted trucks) and the body is at the top, boot/piston on the bottom.
Ron, just curious where you saw that they "ALWAYS" are mounted the way you spoke of. Not trying to start an argument, just curious because my Rancho 9000's and my Bilstein 5100's were both mounted the way I listed above.
Old Jun 6, 2005 | 03:54 PM
War_is_my_Shepherd's Avatar
War_is_my_Shepherd
I don't mean to muddy the waters, but, I've seen triple shock set-ups were two shocks are mounted body up, and the third one is mounted body down on the same wheel. Scanning through the various truck magazines you see pictures of all sorts of variations...up, down, and sideways. Rize Industries "Double Shock Linkage System" has a mod that mounts dual reservior shocks in a horizontal position.
I simply follow the manufacturer's instructions.
Old Jun 6, 2005 | 04:05 PM
skipperw's Avatar
skipperw
I have Edelbrock IAS Shocks and the piston and boot are mounted on the bottom.
Old Jun 7, 2005 | 12:32 AM
jetjock16's Avatar
jetjock16
the way the older style shocks worked they needed to be rod/boot up to help the seal from leaking, keeping the oil and piston away from the seal as much as possible.. now days.. most shocks have pressurized gas in their with the oil, which makes the shock have kind of mulitple stages, and re-act quicker... with the pressurized gas, the seals have been much improved and are always fighting to seal in the pressure, so which way you mount them makes no differance anymore.
Old Jun 7, 2005 | 08:22 AM
krewat's Avatar
krewat
My idea with my Rancho RS9000x's, was to keep the rod UP, because it kept it away from rocks, mud, sand. I don't think there was anything keeping me from mounting them upside down.
Old Nov 17, 2005 | 02:38 PM
jdwharton's Avatar
jdwharton
I'm not sure this is right, aren't Bilstein's mounted with the boot/rod down?
Old Nov 17, 2005 | 02:47 PM
mdpopo59's Avatar
mdpopo59
I think Jetjock and Krewrat are both right. Gas shocks like KYB's are a sealed system and should work the same both ways. You just want to make sure you mount the back ones with the piston rod up so everyone driving behind you can see the MONOMAX stickers.
