I beams/ disc brakes
Josh here. I had a question about drop i beams. I have a 1971 ford f-100 and i was wanting to intal drop ibeams and disc brakes. The problem is that i havent found disc brake conversion for my truck. i was wondering if i could use drop ibeams from a later year and use the disc brakes from that model. Or if there is a way to get disc brakes on the 71 beams.
your help is greatly appreciated
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Enjoy FTE....and
staying with 1/2 ton and 3/4 ton under 6900lbs
65-74 I-beams are identical
65-79 I-beams are identical
the differance is in the kingpin diameter.
73-74 disk brake spindles will mate up with 65-72 I-beams
75-79 I-beams will bolt into earlier trucks but you need the later spindles with them.
f100today
04-02-2016 08:09 PM
1965GTFB
07-10-2013 04:58 PM
Megatron1969
11-09-2010 12:44 AM
