Weird Gauge Problem
Old Jun 4, 2005 | 07:31 PM
jasond5150's Avatar
jasond5150
Question Weird Gauge Problem
Twice in the last 2 weeks I've been idling in traffic when my fuel gauge and temp gauge will peg to the right for about 1 minute and then return to normal positions. The oil pressure gauge and volt-meter(?) aren't affected.
Any ideas what might be causing this? Obviously some sort of electrical problem, but where? We've been getting a ton of rain lately so I'm wondering if its moisture related.
Thanks!
Old Jun 4, 2005 | 08:01 PM
Mil1ion's Avatar
Mil1ion
Popular complaint
Bad grounding-out on the cluster.
Time to remove it and clean it up.
Check the ICVR attachment connection.
Old Jun 4, 2005 | 09:02 PM
jasond5150's Avatar
jasond5150
Thanks, Mil1ion. But, what/where is the ICVR? Is it just the connection from the wiring harness to the cluster?
Old Jun 4, 2005 | 09:18 PM
whalerron's Avatar
whalerron
The ICVR is the voltage regulator that is plugged onto the back of the instrument cluster. It is rectangular in shape and about 3/8" thick. It has a connector on it that is similar to a 9 volt battery connector. The problem could be that the ICVR has gone bad. It is not uncommon for them to die.
Old Jun 4, 2005 | 09:20 PM
zwinstead's Avatar
zwinstead
The ICVR is on the back of the instrument panel. I think its rectangular, althogh I havent seen one in quite a while. The ICVR is Instrument Cluster Voltage Regulator. It regulates the voltage to the gauges and sending units. Most like a faulty connection is to blame for your issue. My truck has been doing that sporadically for many years. Mosture will definately affect it, I live in Louisiana HUMID all the time. As Milon suggested a clean up of the sprinted circuit board and ICVR connections would probably cure it.
Old Jun 4, 2005 | 09:33 PM
Mil1ion's Avatar
Mil1ion
On this illustration they call it an IVR.
Look Just above the word *Speedometer*
http://www.clubfte.com/users/mil1ion...lusterBack.JPG
Last edited by Torque1st; Jun 4, 2005 at 09:51 PM. Reason: big pic, remove img tags
Old Jun 4, 2005 | 09:39 PM
Mil1ion's Avatar
Mil1ion
Here's an actual pic of one.
Old Jun 4, 2005 | 09:52 PM
Torque1st's Avatar
Torque1st
Posting Legend
The oil pressure gauge should have pegged also unless it is not functioning.
