double roller timing chain
Old Jun 4, 2005 | 11:34 AM
hol1942's Avatar
hol1942
have a double roller timing chain for 1987 ford engine want to know is advanced for torque or is retard for torque
Old Jun 4, 2005 | 03:55 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
Where do want want the torque? Advance will get it at lower rpm's, retard will move it higher as well as your power band.
.....=o&o>.....
Old Jun 4, 2005 | 10:57 PM
Torque1st's Avatar
Torque1st
Posting Legend
Talk to the cam manufacturer. They can tell you how to set it up for your application. Normally they are run straight up but some are ground with an offset.
Old Jun 5, 2005 | 06:17 PM
kotzy's Avatar
kotzy
Usually advancing the cam timing gives a bit more on the low end and helps fuel mileage.
