yup, here it is stright off my digital camera from my 97, OBS truck.... hope this helps! I used the stock hose, coupled with a 45* 4" pvc coupling w/ the flanges cut off with a hack-saw and sanded down, then into a 4" collapsable pipe couppling to the filter. Great seal on all fittings....
NOTE: some fellows here have used exhaust elbows etc. to make it look purdy under there... i just haven't had the time...
Probably, so keep your stock box and take the 6637 out and replace the stock box if you have to go in for waranty work. unless you can convince the stealership that the stock box leaks, and this filter works better.
i just put one on my 95 yesterday without the exteded pieces, i just roughened up the filter plastic with some sandpaper, cleaned all the oil out of the stock tube so it wouldnt slip out, then i bought another, bigger hose clap and cut holes in it to fit though weird prices of rubber on the hose. anyway, after i made sure everything was tight i just crammed it into the old airbox area and it stayed.
