80's Cruise control swap to include resume.
I was curious if anyone that has factory cruise or has added factory cruise has considered retrofitting later model parts (80 - 86) to gain the resume feature. I have an 80 model wheel in my truck and it has the resume feature, and it's not in the way or any thing like that, but I thought it would be cool if it worked.
I've done a little experimenting so far. I changed my amplifier for an early 80's model. The off and on button still worked correctly. The resume and coast button work correctly. However the set button does not. When you press the set button the truck gains about 7 or 8 miles more than where you set it before it levels off and actualy cruises.
Anyone have any bright ideas? Is this even possible?
Mike
Mike
Mil1on, We had a miscomunication some where let me start from square one so we can sort this out.
I installed a complete 79 cruise system in to my 73. It took a couple of wiring modifications to the collum, and to the horn relay, but everything worked good.
Next, I put an 80 model truck steering wheel and horn pad on my 79 model collum. Everything worked good just like it did before. Excpet, now I have the extra button on the horn pad which is Resume.
Then I unplugged my 79 model amplifier, and replaced it with an 80 model amplifier. Everything including the resume button worked except when you push the set button to turn set the cruise speed, the truck would speed up 7 to 8 miles faster than where I had originally set it before it leveled off and maintained speed.
Just to double check that nothing was wrong as far as the original 79 components, I unplugged the 80 model amp and went back to the 79 model amp.
Now everything works right again, except the resume button which does not work at all.
Do you have any ideas?
Mike
Mike
Read me the numbers off both amplifiers (black Boxes).
Because the resume was another feature in the 80's I'm positive the circuitry had changed slightly.
I can't think of any other component that would be affect the system.
Everything else is mechanical.
There is a guide for figuring out what causes the speed to change.
Perhaps that feature was shot in the 80's amplifier ?
