Van stalling
Old Jan 5, 2000 | 02:01 PM
danw's Avatar
danw
Van stalling
I have an 84 Ford E-150 300\C6 van, 54k original well maintained miles.
In the past 6 months I wasted $900 bucks for nothing. The problem
started 2 years ago with it stalling in the winter, this past summer the
carb was totally rebuilt. It was fine until the cold weather set in.
When initionally starting it I tap the gas pedal and I can hear the
chock close, turn the key and it starts right up, with the chock still
engaged I have to let it warm up for 15 minutes until the motor is
well heated up. If I don't do this it will stall and will not start back
up until an hour or so passes. The other night it started I went in
the house came back out and it was'nt running, it would not restart.
The next morning it would not start either, I had it towed paid, $535
ignition wires, rotor and some other electric things and this morning
I figured why let it warm up after all that, but what do you know
"BINGO" it happened again.
So my question is should I just install a manual chock?
Any suggestions. One more thing I should point out, then it's started
and the chock is closed it sometimes will race wildly until the chock
is kicked off.
My E-mail is danw@home.com, but it would be better relping on the board.
Old Jan 6, 2000 | 01:42 AM
Jay's Avatar
Jay
Van stalling
Take the truck back to the shop and tell them the work they done hasnt solved your problem leave it over night and let them start it when its cold so they can experience the problem and fix it.It sounds like your choke isnt working properly and you might need some adjustments. If you dont know about carbs youll probably make it worse by trying to adjust it yourself.
If all it needs is to be adjusted maybe the shop wont charge you beeing you spent all that money to fix it and still having the same problem.
It all depends on how you approach the situation how good you are with words and how head strong you are.
Good luck.
Old Jan 6, 2000 | 10:39 PM
mholota's Avatar
mholota
Van stalling
