I have a '95 f-250 psd that's having some isues. about a year ago the cargo and dome light started staying on for hours after the door was closed and constantly while running. At first I thought gem sensor but when I called ford they didn't list a gem for diesels. I didn't get too worried I just pulled the bulbs out until I had time too get to the problem. Well now I have no choice because every time I have a trailer hooked up with the trailer brakes on the pickup won't idle. When I turn the brakes off it runs fine.
I don't know if the two problems are related but I really need some help.
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Welcome. The dome light is probably the switch on the door. It is located in the latch on the door. Spray it down with WD-40 and it should start working right again. You may have to soak it pretty good. The trailer brakes cutting the truck off is a puzzle to me. I'll have to think about that one for a while.
Joe
Joe
I thought of that and checked it with a test light, and found it was in working order. So who knows.
