Oxygen sensor location
Old Jun 3, 2005 | 03:26 PM
pilot815's Avatar
pilot815
Where are the Oxygen Sensors located on a 2001 Sport Trac? I now have 81,000 and i pulled codes on it and it said i need to change the sensor in bank 1. However, if someone could tell me where they all are, this sounds like a good project for this saturday.
Old Jun 3, 2005 | 04:51 PM
Cylinder Head's Avatar
Cylinder Head
O2 sensor
It depends on what motor is in it ,a standerd V6 or V8 would have an O2 sensor on each bank and after the cat. You will need an O2 socket to get them out.
Old Jun 3, 2005 | 09:13 PM
thelonerangerxlt's Avatar
thelonerangerxlt
Arrow
Bank 1 is always the side with the number 1 cylinder, which is the passenger side on the Ford V6 and V8. If the code shows sensor 1, then it's the one nearest the exhaust manifold (upstream), if number 2, then it's the downstream sensor.
The same applies to bank 2, drivers side.
Old Jun 4, 2005 | 12:10 AM
pilot815's Avatar
pilot815
Now is upstream, the tubes that run down to the cats, and downstream is at the cat?
Old Jun 4, 2005 | 11:37 AM
87 XLT's Avatar
87 XLT
Upstream is on the engine side of the cat, downstream is on the other side of the cat.
Which code did you pull?? If it's a lean code thats caused by a vacuum leak or an O-2 circuit open code, changing the O-2 wont help.
Old Jun 4, 2005 | 12:35 PM
pilot815's Avatar
pilot815
Not sure what the code was, i took it to advance auto parts, and they printed out a thing saying engine running lean on bank 1. Because of the vehicle having 81,000 miles i figured thats what it would be. How do i check for a vacuum leak?
Old Jun 5, 2005 | 02:17 AM
87 XLT's Avatar
87 XLT
If you are real lucky a bottle of injector cleaner in the gas will clear this up. A clogged injector can cause a lean code on one bank only.
Another thing you can try is to use a piece of garden hose like a stethoscope. Just poke around with it and see if you can hear a vacuum leak around the intake manifold.
P0171 is the code for lean bank one. Try doing a forum search on the code & see what you come up with.
Odds are the O-2 sensor is NOT the problem.
Good luck with it.
Old Jun 5, 2005 | 02:25 AM
pilot815's Avatar
pilot815
Looked at the vacuum hoses, and they looked fine. So i decided to put a new o2 sensor in it. It was the o2 sensor. Now the sport trac is happy, and so am i now that the mileage will increase.
Old Jun 5, 2005 | 03:52 AM
87 XLT's Avatar
87 XLT
Well i'm surprised that it was the O-2, but the main thing is that you got it fixed. Glad to hear it.
rbrackett807
1997 - 2003 F150
Sep 27, 2011 10:43 AM
Ozz13
21
May 7, 2007 10:34 AM
95-explorer1
Aug 29, 2005 10:14 PM
jetd57
Aug 25, 2003 11:59 AM
mlkull
1983 - 2012 Ranger & B-Series
Feb 5, 2003 05:40 PM
