Roll Bar Question
Old Jun 3, 2005 | 01:39 AM
The67Beast's Avatar
The67Beast
Roll Bar Question
Hello,
I would like to add a roll bar to my 67 4X4 Styleside, but cannot find one specified for the 67 thru 72 trucks. I have found some for the 73 trucks, but am unsure if it will fit my truck. Grizzly makes a Double/Single Bar that is exactly what I am looking for except that it is for the 73 truck.
My question is; will the Roll Bar for the 73 fit in the bed of the 67 thru 72? I know that Ford made some changes from 1972 to 1973, but did those changes affect the inside width of the beds?
Has anyone with a 67 thru 72 installed a roll bar? If so what brand and where did you make the purchase?
Thanks.
Old Jun 3, 2005 | 07:44 AM
4Cammer72's Avatar
4Cammer72
it should be the same. i dont think any major changes came until well after that time
Old Jun 3, 2005 | 03:45 PM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK
A lot of the roll bars are made were the rear legs and feet mount to the
wheel well, thats where you may find a problem, the wheel wells in a 67-72
are kind boxy ,flat sides and top, 73-79 wheel wells are like a bump in
the metal, and they aren't near as tall.
Old Jun 5, 2005 | 05:31 PM
thesprocket26's Avatar
thesprocket26
Now is it a roll bar or a show bar? Those things have cheap bolts and wont hold up on a rollover.
Old Jun 5, 2005 | 07:06 PM
bertha66's Avatar
bertha66
Made the rollbar for my 66 4x4 myself out of thick wall water pipe. used 2" standard pipe with I think 1 3/4" inside for double thick walls, then bent to fit the truck. I welded the legs on going bown to in front of the wheel wells. Mounted it on a 1/4" steel plate, then bolted it to the bed floor. Worked real well when my son got hit by a deer and rolled the truck into the bar ditch onto it's top.
Old Jun 6, 2005 | 07:05 AM
The67Beast's Avatar
The67Beast
I guess it would be a show bar that I am looking at. Not a functional roll bar. I may have to find a 1973 and take some measurements of the wheel wells to see how tall they are in comparision to mine.
Thanks for all the advise.
whiteisright
Aug 18, 2011 09:26 PM
iggybob44
Aug 29, 2008 09:50 PM
wreckhaul
27
Mar 8, 2007 09:41 AM
The67Beast
Aug 30, 2005 12:27 PM
jdawg78
Feb 3, 2003 02:12 PM
