fuel rail pressure
Old Jun 2, 2005 | 09:45 PM
rustyoldford's Avatar
rustyoldford
fuel rail pressure
Runs occasionally, when it doesn't no fuel pressure in rail and pump doesn't run. Have already replaced fuel pump relay, cam jump relay and get pressure, is there a sensor in fuel rail or oil line that would cut power to relay. And if, where is the little ______ hiding
Old Jun 4, 2005 | 08:12 AM
lee's Avatar
lee
Hi,
Need more info.
What model truck is this?
What engine does it have?
You wrote that you replaced 2 relays and now have pressure. ???? Is it fixed?
If the pump runs intermettently(sp) it sounds like a connection problem. Have you replaced the pump?
I don't know of any sensor (other than the collision switch) that would stop the pump.
Good luck,
Lee
Old Jun 4, 2005 | 09:36 AM
rustyoldford
Lee
89 f150 302
pressure comes and goes, with the stalling, long rest breaks,,,, took 2 hours to get boat from behind garage, now I'd like to take it to the lake
Hot wireing the pump keeps pressure up, code scanner reports nothing, but engine light keeps flashing
Old Jun 5, 2005 | 11:08 PM
LxMan1's Avatar
LxMan1
Could be the EEC relay. It triggers the fuel pump relay.
Old Jun 10, 2005 | 11:13 AM
rustyoldford
Not sure about the eec relay yet
hot wired pump, won't start, sputters with ether(small sputters)
seems to crank easy (don't notice compression- spins right along like plugs out) was 100- 150 4 months ago. Timing chain?????????
Old Jul 5, 2005 | 12:01 PM
rustyoldford
weathers been bad, I've been lazy, plus 3 more excuses
Compression still the same as before,
have rotated distributor as far as it will go both directions, no change in poping, letting pump run for 10 minutes produced an almost start, and using a longer toothpick on schrader valve results in a beeter dischage of gas then my finger tip produced trickle, I may have better pressure then I thought
But still won't run
Old Jul 5, 2005 | 12:35 PM
220k-f-150's Avatar
220k-f-150
I am going back to your first post. Jump terminals on the oil pressure switch. If it runs then, its either oil pressure switch or lack of oil pressure.
Old Jul 5, 2005 | 11:01 PM
LxMan1's Avatar
LxMan1
You need to check the actual fuel pressure.
