Still Cant Get Spark
Old Jun 2, 2005 | 04:36 PM
donnietruck's Avatar
donnietruck
Exclamation Still Cant Get Spark
Does Anyone Have A List Or Some Type Of Printable Sheet On The Troubleshooting Procedures For An Inline 6 300 Ford Custom F100 1981 Or Can You Tell Me Such Procedures IT TURNS OVER ALL DAY LONG BUT I CANT GET IT TO FIRE IS THERE A WAY I CAN HOT WIRE IT TO GET IT TO A SHOP? OR ARE THERE SOME WAYS TO SAY TROUBLE SHOOT THE ALTRNATR,VOLTREG,COIL,BRAIN & ANY OTHER COMPONENTS THAT MAKE IT SPARK
Old Jun 2, 2005 | 11:25 PM
pburress's Avatar
pburress
No expert here, but I just bought an '82 f150 and have been trying to get it to run right.
At the parts stores they sell service manuals that detail these things such as troubleshooting/testing components.
A wild guess on your problem is that the igintion control module may be bad. Apprently these go out a lot. I paid $26 for one the other day.
Old Jun 3, 2005 | 06:53 AM
F3Beam's Avatar
F3Beam
I guess I'd start by taking the coil wire from the center of the distributor and place the end near the engine and see if any fire is jumping. If it is, maybe take the dist cap off and make sure the rotor was turning when cranking.
If no fire, coil may be bad. I don't know much to do with electronic brains. If alt and regulator problems, it should still fire as long as the battery is hot..
Old Jun 3, 2005 | 11:00 AM
jbhjlch's Avatar
jbhjlch
I have just gone through an ignition problem with my 84 F250/460 V8. I have the duraspark II ignition (silver control box on the driver's side fenderwell). With this ignition system, you can take the box to a local parts store (i.e. Autozone) and they can test the control box, though a replacement is around $20 for aftermarket or $45 for OEM.
When the engine cranks, the reluctor on the distributor shaft rotates past the magnetic pickup in the bottom of the distributor, breaking the magnetic field (hall effect). This sends a signal to the ignition control module, which sends the signal to the coil to fire.
So here are some test you can run. As suggested, first get a Haynes or Chiltons manual, they have good pics and tests. If you have a good digital volt meter you can measure the voltage between the batt (+) terminal of the coil to the distributor base (ground). You should see around 10-12V when cranking, and probably 6-8V when in run. If you have voltage there, you can also check the voltage between the tach (-) terminal of the coil to ground, which should be around 1.5V (if memory serves me).
Then you can check the resistance of the coil from the + to - posts, should be between 7000-10500 ohms. You can also check the + to center post, can't remember the spec but it is in the manual.
If your DVM has a frequency counting setting, which some of the mid- to upper- range ones do, then you can put it across the + and - posts of the coil and watch the frequency when you are cranking. If you are getting a frequency signal (maybe around 500Hz), then your everything in the signal path up to the coil is working. If not, then likely your control module is dead or the pick up in the distributor.
Finally, if you check for spark to the distributor cap and it is good, then check at your plug 1 wire. I had to replace basically my entire ignition because of age, problems, etc... Hope this is helpful.
Old Jun 3, 2005 | 11:30 PM
donnietruck
Sir Thank You Very Much I've Taken The Ncontrol Modual Off & I'm Headed To Azone Now Wish Me Luck .also Thank You Very Much All Who Have Responded To My Plea For Help God Bless
