key things that should be noted
Old Jun 3, 2005 | 11:32 AM
Scouder's Avatar
Scouder
Originally Posted by debestuss
Explain this whole stretching rod bolts thing. What I'm gathering here is that having them torqued to spec isn't enough?
A torque spec is really a measure of friction, not clamping force. Though they are related. Stretching the rod bolts assures a consistent and adequate clamping force. Millions of engines are running successfully with torque method, so it's not something to lose sleep over, but stretching is more accurate.
-Scouder
Old Jun 3, 2005 | 11:37 AM
bshackelford711's Avatar
bshackelford711
Originally Posted by FalconStng
Get Steve Christ's book before you start. "How to Build Big Block Fords". If you pick up just one thing that you would've messed up then it'll be worth it. As for me, it saved me on the cam plug that Six spoke of. The machine shop I used put it in backwards...I wouldn't have known myself had I not picked the book up and read it.
does this book have any spec for the FE motors?
Does anyone have any specs for a 390?
like clearances and trq specs and thing such as that.
Old Jun 3, 2005 | 12:49 PM
FalconStng's Avatar
FalconStng
All that and more. There are casting listings so you can identify what you have. It also has very detailed disassembly/reassembly instructions. I've built many engines over the years...though never an FE before. I almost didn't buy the book because of my past experience. I'm really glad I bought it...it's chock full of info.
Tracy
Old Jun 3, 2005 | 01:09 PM
bshackelford711
i will order that from summit today
Old Jun 3, 2005 | 07:35 PM
hiball3985's Avatar
hiball3985
be sure to check your ring end gap, if you not racing ARP bolts seem like a waste, the stock bolts ran in thousands of 390's, Ive never seen one fail
Old Jun 3, 2005 | 11:46 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
After you've destroyed a 428 block, cam and couple of rods, look at the money you saved without running ARP bolts. Done that in the 70's, never again unless your stupid, rich or never go over 4,000 rpm's. Just my financial way of thinking.
.....=o&o>.....
Old Jun 4, 2005 | 08:23 AM
UncleFudd's Avatar
UncleFudd
Hey Beemer
Try to get a "coating" of lubricant on all surfaces. The metal, being porous will only retain a "boundry layer" after all. The rest drains off. So putting on lots of it is really messy and not efficient.
Stay away from the WD40 on any surface that you want to have or retain a lubricating, non-friction action as the WD40 will wash away or out all or most of your lubricants including the grease in sealed bearings.
I once lubed the aileron bearings in an F27 Fairchild aircraft as the sealed bearings were a little stiff. It really freed them up nicely, but the inspector who looked at my sign-off, wrote it up and we had to remove both ailerons and replace all of the bearings and then had to perform a test flight of the aircraft. Expensive and it nearly cost me my airline career very early on.
WD40 is good for many things, rust inhibitor or prohibitor and lubricant it is NOT.
Old Jun 4, 2005 | 08:44 AM
hiball3985's Avatar
hiball3985
like most engine failures, the problem is the driver not the parts, used in the operation range they were designed for they don't fail
Old Jun 4, 2005 | 09:15 AM
Six Niner's Avatar
Six Niner
Originally Posted by xfordman
'Falcon......from what I hear that assbackwards cam plug thing is common, but you would have caught it anyway because the cam wouldn't have gone all the way in, it would hit the plug.
actually the cam will go all the way in and the engine will run! i went through the whole ordeal. i just hope i got all the metal shavings out.
Chevy_Eater
82
May 21, 2025 08:15 AM
akamacgyver
Jul 30, 2017 06:13 PM
Ironpants
36
Apr 26, 2014 08:44 PM
Submarine Docker
Nov 8, 2013 08:34 PM
85vanman
May 18, 2002 11:02 PM
