Bronco II Ford Bronco II
Instrument voltage regulator??
Old Jun 2, 2005 | 01:00 PM
pollock's Avatar
pollock
My gauges have never worked right (except the speedo). The tach is inaccurate.
The gas gauge, oil pressure, voltmeter, and temp all read zero all the time. I have an aftermarket oil gauge for safe keeping.
I've read previously about an "instrument voltage regulator." Is this what I need to replace?
Old Jun 2, 2005 | 04:50 PM
87 XLT's Avatar
87 XLT
what are you driving?? I might have the wiring diagram for it.
Edit, try this simple little test. Turn the key to run-not start- & have someone watch the temp gauge while you remove the wire from the temp sending unit, shove a nail in it & ground it to the block.
The gauge should move to full hot.
Old Jun 3, 2005 | 04:11 PM
80`F-150's Avatar
80`F-150
My voltmetere stays in the middle,rest work. cool trick
Old Jun 6, 2005 | 03:39 PM
pollock's Avatar
pollock
Thanks for the info.
It's an 89 Bronco II, 2WD, A4LD, 2.9L. Full set of stock gauges.
I'll give your test a try.
