Looking to pick up an msd 6al and either the blaster 2 or 3 coil... does anyone have any experience with these products and where would i look to find a performance distributor for the 2.9 because form what i have readthe stock will not stand up long to this sort of power upgrade going through it let alone the stock cap and rotor... since i have finally gotten the b2 back into stable condition its time to continue the buildup.. so any info would be greatly appreciated
how do these fair monty? ive read reviews witht hem quitting in the middle of their service life or even a week after being used... also you said a while ago you changed and put a flex fan in rihgt? is it the same 16 inch or did you go bigger or smaller? and does the flexible steel tubing for the cooling system have a beter effieceny rating than its rubber counter part.. it seems like the water is picking up extra heat from the valve covers as it passes into the heater core ?
i have a 18inch flex fan and yes it does alot better than it's counter part .alot less wieght on the pump. as for themsd parts i found that most of the stuff is used but sometimes you find new items for alot less
as for my msd system total for me was 300 bucks
i have a 6a offroad version with rev limiter,blaster coil,spark plug wires msd,and accel cap and rotor. using bosch platinum4 plugs. so i know that there are good deals out there.
monty ...do you happen to know what the model number is on that fan you got there? its getting hot and i need to keep this baby nice and cool and since its an allblack it heats up pretty quick and the stock fan is having a little trouble keeping it back to the "M" in "norm" nowadays and anytime after that i start having problems that i havent been able to track donw.. still searching out all the grounds to make sure they are attached properly..
