spark plug number
Old Jun 1, 2005 | 10:39 PM
strato1's Avatar
strato1
spark plug number
Can someone tell me what the part number is for spark plugs that will fit my ECZ-G heads? I bought them from a junk yard and they had no plugs in them. Of course none of the parts stores around here have books that go back far enough.
Thanks!
Old Jun 1, 2005 | 10:43 PM
strato1's Avatar
strato1
Crank shaft pulley trouble
I'm rebuilding this 292 and I can't get the crank pulley to go all the way back on. It goes all the way on except for the last 1/4". I even broke my harmonic balancer installer getting it on as far as I did. I even took a die grinder to the end to try and open it up, but that didn't help
If I can't get it on is there any harm in leaving it out the 1/4" and then just shimming the water pump pulley to match it up?
Please help!!
Old Jun 1, 2005 | 11:00 PM
rogerf100's Avatar
rogerf100
Pull it off and check the groove for the woodruf key. It may have a bur. Also check the woodruf key to make sure it is not too large. You can remove the key by prying it out of the crank snout. Then try to test fit the pulley without the key to see if it goes on. There is something blocking it. Keep trying you will get it. It needs to go all the way on. The crank pulley on my 292 was a tight fit so I used some emery cloth on the crank to smooth it.
