Compression Test
Old May 27, 2005 | 09:44 PM
66BroncoWA's Avatar
66BroncoWA
Compression Test
I have a 62 4X4 F100. It is complete except for the engine. I have a chance to buy a 64 F100 with a 292 (not 4X4). The asking price is $500. The engine starts right up and seems to run well with the holley 4 barrel. However, I did a compression test... Most cylinders tested between 110-130 with not difference between wet or dry. However, the #5 cylinder test at 60, both wet and dry. Would this be worth my while? It would be an easy job to pull the engine from the 64 and get my 62 on the road. Would this be worth my while?
Thanks,
Old May 28, 2005 | 08:38 AM
57_ford's Avatar
57_ford
110/130 doesn't sound bad the #5 cylinder wet doesn't bring the com back might just mean that one of the valves in that cylinder is eather adjusted to tight (solid lifters) or is burned. You could try and loosen the valve adjustment and try again.
Old May 28, 2005 | 09:44 PM
66BroncoWA's Avatar
66BroncoWA
Can you tell me how to adjust the lifter? Or point to where I can find out how?
Thanks,
Russ
Old May 29, 2005 | 07:06 AM
57_ford's Avatar
57_ford
Remove the valve cover. Turn the engine over until # 5 is tbc and make sure that it is on the compression stroke. Both rocker armes for that cylinder should have slack in them. The adjustment should be set to .019 with a set of feeler guages. The measurement should be taken between the top of the valve spring and the rocker arm.
Their is a lot of good info for these engines here, www.ford-y-block.com and at
www.y-blocksforever.com
Old Jun 2, 2005 | 07:41 AM
f700's Avatar
f700
sound,s like val ajustment to me , i think 57_ford said it well check number 5 and retest , let us no how it go,s ok
Old Jun 2, 2005 | 09:07 AM
66BroncoWA's Avatar
66BroncoWA
Unhappy
I wasn't quick enough on the draw :-(
I was going to go back to get it, based on the idea that it was (hopefully) just a valve adjustment. It was gone.
I'm back to looking.
Thanks,
Russ
c2z4s9
73
Feb 29, 2016 07:14 AM
Pad2383
15
Nov 4, 2012 01:30 AM
caddywhompus
1978 - 1996 Big Bronco
23
Jun 28, 2004 09:32 AM
jbondi
Modular V8 (4.6L, 5.4L)
Jun 10, 2004 03:17 PM
Guy
May 25, 2000 12:53 PM
