My tranny just started shifting wierd when i got the truck running after doing the mods in my signiture.
It shifts out of all gears early and damn near skips 2nd. It will sometimes rev up before it shifts to od and won't go in untill i let off the throttle. also wont down shift in any gear unless i almost floor it
before i did the mods It would shift into 3rd a little early but no where near as bad as it does now. The down shifting problem was also there but not as bad. never had the problem with shifting into od though
93' F 150 4x4 5.0 converted to MAF with A9P ecm, full exaust FMS shorty headers no cats 40 series flows, FMS B303 cam, 1.72 ratio cobra roller rockers, mustang intake, 70mm bbk TB, 80mm MAF, 24# injectors and removed all smog equipment.
I had to make a new barcket for the throttle and tranny kick down since i used a mustang intake, but i made the kick down braket adjustable so i could adjusted right
