C6 Question?
Old May 25, 2005 | 05:37 PM
Wideopen232's Avatar
Wideopen232
C6 Question?
I recently bought a 79 CC 4x4 with a 460 and the C6. I need overdrive bad.
Lots of freeways around here. I know there is the Gear Vendors option out there for the overdrive. Is there any other option out there that would give me an overdrive. I tryed searching around but I didnt see any other threads that talked about it. Also I want to stick with the automatic.
Thanks
JC
Old May 25, 2005 | 08:15 PM
mark a.'s Avatar
mark a.
Not that I know of. Let us know if they do make them and what it cost.
Old May 26, 2005 | 06:59 AM
RTM's Avatar
RTM
Install a ZF 5-speed would be the easiest and cheapest to do.
Old May 31, 2005 | 01:24 AM
wideopen23's Avatar
wideopen23
what is a ZF 5 speed exactly?
Old May 31, 2005 | 06:18 AM
Steve_Uzi's Avatar
Steve_Uzi
As far as automatic overdrive the the 460 - forget it... it will cost you lots of $$$$ ($2500 at least) and in the long run you MIGHT get an additional 3-4 mpg. If you do the math you probably won't make up for the $2500 or so for a few years...
I agree, get the ZF 5 Speed manual.
Old May 31, 2005 | 05:28 PM
wideopen23's Avatar
wideopen23
yea the gear vendors are expensive. Is this ZF 5 speed a ford tranny?
What did they come in and what does it itake to make it work?
Old May 31, 2005 | 05:40 PM
53fatfndr's Avatar
53fatfndr
Other options would be to change your gear ratio in your axles or even go to a larger diameter tire size. These would drop your RPM. However, since I see you drive a 4X4, you may not want to do that for when you go offroading. On the other hand, if you have 4low on when in 4 wheel drive, you could still crawl pretty darn good for offroading, depending what all your gear ratios are.
Old Jun 1, 2005 | 01:03 PM
wideopen23's Avatar
wideopen23
I thought about that, I am running 35 inch tires know. I know this helps, I was told by a friend that if I went to a lower gear than the 410 the truck would be a pig when towing. I dont know if this is true or not, any ideas.
I still dont know anything about this ZF 5 speed?
Old Jun 1, 2005 | 02:37 PM
stuart1's Avatar
stuart1
With 460 engine you can go to very different gears. Even 3:00 would be ok.
I had an 86 F150 with a 351C and 3:00 gears. Could really haul *** with it.
Old Jun 1, 2005 | 04:34 PM
53fatfndr's Avatar
53fatfndr
I have 4.10 gears with 33 in tires on my '79 F350 4X4 with a 400. Although it is a standard tranny with 1st gear being a granny gear, it still pulls really good. I routinely pull a weighted down trailer. My only change was going to a bigger tire as the gears were stock. My rpm's dropped a bit, but that was all. Really, IF you notice a diffrence you will just have to change your driving style a bit.
Old Jun 1, 2005 | 06:57 PM
84-250's Avatar
84-250
the zf is a 5sp used in 88 and up f250 and f350. it has the following gear ratios, 4.14, 2.37, 1.42, .77 .i may be off on the first gear ratio. so you get ratios that closely match a c6 while adding a granny gear and overdrive. a c6 has ratios of 2.46, 1.46, 1.
