need advice for 1997 explorer limited
Old May 31, 2005 | 11:40 PM
snooz's Avatar
snooz
Unhappy need advice for 1997 explorer limited
Cut to the chase: the two lower brake lights (not the one over the rear door) are not working...I checked the bulbs, then fuses and those are fine. And when they aren't working, niether is the auto door locks when putting the car into motion - whether that's activated by tranny ? I'm at a loss on this one. The truck is in excellent shape - no damage to any lights past or present. It seems to be intermittent as well, as occasionally the lights and auto door locks will work. Anyone have any ideas?? Any help would be greatly appreciated.
S.
Old Jun 1, 2005 | 04:01 AM
87 XLT's Avatar
87 XLT
A good guess would be a flaky lamps out warning module. The outer brake lights are wired thru it, but the center brake light is'nt.
Old Jun 1, 2005 | 10:18 AM
snooz's Avatar
snooz
hey 87
Sounds like good advise, thanks! I'll check that first. So where is the module located? (I realize I should have a manual for it and will be getting one immediately) Thanks again for your help...
Old Jun 1, 2005 | 12:32 PM
87 XLT's Avatar
87 XLT
If you have a lamps out display on the dash, you also have the lamps out warning module. It's under the center console.
The best manual for electrical problems is the Ford "electrical & vacuum troubleshooting manual" from www.helminc.com or you might find it on ebay.
Good luck with it.
Old Jun 2, 2005 | 09:16 AM
snooz's Avatar
snooz
Hey thanks XLT for the great advice. It was the module and I didn't need to replace it, just tighten and clean the connection...
Thanks again.
Old Jun 2, 2005 | 10:50 AM
87 XLT's Avatar
87 XLT
Thanks for the update, glad to hear you got it fixed.
