low idle question
Old May 31, 2005 | 08:25 PM
rudder9's Avatar
rudder9
Question low idle question
I have a 95 bronco w/ a 5.0l. My question is , why does it idle lower when it is cold,then gets to normal idle after about 20 mins. This happens after the normal high idle for about a miute. I have done some mods. to the engine.They include: a cam FMS e-303,pulleys ,80 mm MAF sensor, edelbrock manifold, 24lb. injectors,BBK 56 mm twin t.b, Headers,exhaust,full MSD ignition incl. dist.Afr heads and Crane roller rockers. It will only do this when the engine is cold after it is warm, every time you start it, runs fine ?
Old May 31, 2005 | 09:37 PM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum.
