Replaced the EGR sensor - that fixed the 334 code. Anyone have any idea where the canister purge solenoid is??? I assume it refers to the purge canister located on the passenger side fender well. There is no solenoid attached to this. WTF!
follow the vacum from the canister goining to the intake,solenoid is usually spliced into that vacum line!i would not worry about the purge solenoid,it usually sets a code when you have a egr problen or other emission problems!
