wiring harness question
Old May 31, 2005 | 08:07 PM
76hi-boy's Avatar
76hi-boy
would a 1976 wiring harness fit my 1977 truck?
Old May 31, 2005 | 09:42 PM
thesprocket26's Avatar
thesprocket26
Yes. As long as it had the same options and came from the same size and model of a truck.
Old May 31, 2005 | 10:30 PM
Mil1ion's Avatar
Mil1ion
The difference between the 2 is the connector for either gauges (18 pin) or Idiot lights (14 pin)
If you don't have it,I recommend getting the one for gauges rather than the idiot lights,then get a gauge cluster.
2) Another difference is the transmission B/U lights-NSS system.
3) The 77 came with the hazard light switch on the column
Does your 76 have that ?
Old Jun 1, 2005 | 06:27 PM
76hi-boy's Avatar
76hi-boy
who makes a wiring harness for a 77 f150 short bed auto with 4x4?
Old Jun 1, 2005 | 06:55 PM
bulrydr_1's Avatar
bulrydr_1
No one "makes" a harness custom fit for our trucks that I know of. I got a complete bumper to bumper harness that worked very well for my 77 from painless performance. A bit pricey, but it came with everything I needed to completely rewire the truck, to include a 12 circuit fuse block. I did have to do some splicing for the the specific light connections, dash cluster, etc. The also have an awesome support department if you run into any snags!
painlessperformance.com is the site. You can't order directly from them, but a few of the FTE sponsors can get them for you....
Hope this helps!
Old Jun 1, 2005 | 07:02 PM
Mil1ion's Avatar
Mil1ion
Oh Yes there is
www.centechwire.com
76hi-boy's Avatar
76hi-boy
i just looked they make one for 67-77 fords
Old Jun 1, 2005 | 07:05 PM
bulrydr_1's Avatar
bulrydr_1
Ok, ya'll got me. I looked for 6 months and couldn't find anythng, so I went with the painless system. At least it was about the same cost! Let us know how it works if you go with it.
Old Jun 1, 2005 | 07:08 PM
76hi-boy's Avatar
76hi-boy
how much are the painless systems?
Old Jun 1, 2005 | 07:11 PM
bulrydr_1's Avatar
bulrydr_1
The one I went with, 12 circuit universal, was about $400. As with anything else, the more options, the more expensive.
76hi-boy's Avatar
76hi-boy
my problem is that the running lights only come on when the truck is not running and when there on the brake lights dont work, only one headlight comes on. the signals are on a toggle.and the radio and tach light come on when i hit the brakes.
Old Jun 1, 2005 | 07:13 PM
Mil1ion's Avatar
Mil1ion
You have a T/S switch & grounding problems with that truck
Old Jun 1, 2005 | 07:16 PM
76hi-boy's Avatar
76hi-boy
the wires are cut coming out of the column too.
Old Jun 1, 2005 | 07:17 PM
bulrydr_1's Avatar
bulrydr_1
I agree with ya Dennis!
I had to replace my harness because the owners over the years hacked it all up and several wires was melted together. You will most likely be cheaper off by grabbing a multimeter, and a schematitic and troubleshooting it yourself.
Old Jun 1, 2005 | 07:20 PM
Mil1ion's Avatar
Mil1ion
The only thing the *engine running* is doing is sending power from the alternator to the battery.
Yet another grounding problem
