well the only wiring in the column is hanging out of the column about 2 inches. they are hookied up in the column but the previous owner cut the wires, so they are not hooked to anything. so i guess its worth a shot to find the other end of those wires under the dash and rehook em together and replace the t/s switch. i think thats where im gonna start because i dont really have 400.00 to spare. keep the info comin. thanks
well im still on crutches from "THE ACCIDENT" so heres what i got right now.
these are the wires coming out of the column that are cut:
Green
light green?
blue
yellow
these are the ones that appear to be connected:
red/white
red/black
red
blue/yellow
light blue
Check that blue/red stripe.
That wire goes to the transmission selector light
The wire is well known to break off & touch the metal column, short out & blow a fuse.
mil1ion- i took a look at the 2nd link on your post and i found that half circle shaped plug and it seems i have more problems... on the top row(the longer side) these are the wires in those 7 holes..1.empty 2.red/blue(not lt. green) 3.lt.blue(correct) 4. gone 5.gone 6.white/red(correct) 7.gone
i was tracing the harness to the tail lights and coming through the rear cross member is a plug the wires going in are yellow/black,light green,brown,black/red
but the wires going out are light green,yellow and black,and 2 brown/blacks and one that i think might be a ground but that one is cut. any ideas? also on the framerail about in the middle of the truck there is a blue wire that has a end on it that kinda looks like a spark plug wire end but its not hooked up to anything, does anyone know what that is and where its supposed to be plugged in?
Sounds like a harness has been exchanged.
solid brown is marker/running lights
also on the frame rail about in the middle of the truck there is a blue wire that has a end on it that kinda looks like a spark plug wire end but its not hooked up to anything, does anyone know what that is and where its supposed to be plugged in?
probably related to fuel tanks,
do you have a single tank ?
